No need to modify the klipper source code
A project log for Bed leveling sensor
Give you amazing first layers
markmark • 08/01/2023 at 06:45•4 Comments
 No need to modify the klipper source code with latest code on githube for BD sensor.
https://github.com/markniu/Bed_Distance_sensor
joejoe317 wrote 08/11/2023 at 06:50 • point
also I saw you referenced a chip I’ve used before tca355g, did you just figure out how to use the capacitance chip, then found one for inductance?
joejoe317 wrote 08/11/2023 at 06:49 • point
when I go to the link, then on bottom click klipper it then takes you to how to patch klipper. Does the install instructions need to change, or am I misunderstanding what this means? I already have klipper, so I have to patch and reinstall?
mark wrote 08/07/2023 at 02:20 • point
I have tried to let the real time leveling work with klipper but not stable due to the speed limit of MCU to RPI, Maybe there are other solutions that I haven't found yet.
jan.noname wrote 08/03/2023 at 14:44 • point
Why doesn't the real time leveling work with Klipper?
