The first controller had some issues which I addressed in this hardware revision.
- The footprint of the logic level shifter (U5) was fixed.
- Added an RGB status LED.
- Added a reset button.
- Added a mode button to select the Wi-Fi mode.
- Changed the right angle box header to a straight box header and changed the orientation 180 degrees.
- Changed the board dimensions to allow for the extra components.
- Changed the relay driver to a mos-fet + diode because of component scarcity.
The Top-Con board was updated as well, this was done so all components can be mounted on the same side.
