I uploaded the dxf for the front panel holding the elecrronics from the nitfty case. Missing the holes of my headphone stereo output, since I drilled it afterwards. It can maybe used to make a 1U panel as well, it almost look like 1U but its not.
Lost the standoff which hold both the rails unfortunately but those schould be done fitting your briefcase and pieces of wood anyway.
Tillo
