Wave Energy: Efficient Conversion of The Big Waves
The gravity and buoyancy forces of ships are used for pumping water.
Public Chat
0 followers
Tidal force on a floating object has two elements: 1) Horizontal force: This is a one-directional force created by tidal flow/current. 2) Vertical force: This is a bidirectional force created by tidal waves with gravity. Tidal horizontal force (and with other external any kind of wind forces) on a floating object can be opposed by anchoring it properly (by using a minimum of four horizontal/ long-distance anchors) so that the vertical force remains almost the same. This vertical force is useful and it can be very much useful as easily increase this vertical force by Archimedes Principle (by increasing the size of the object). This bidirectional vertical force is very much suitable for pumping purposes. By installing pumps inside the ship, using the vertical bidirectional force of the wave and gravity on an anchored floating object continuously sufficient water pumping is possible for hydropower station and or desalination
The objective of this submission is to describe how we can get the maximum amount of working force from tidal wave energy. Defining various forces acting on a floating object, how we can handle unnecessary forces, how can increase useful force, and use it safely. Tidal force on a floating object has two elements: 1) Horizontal force: This is a one-directional force creates by tidal flow/current. 2) Vertical force: Is a bidirectional force creates by tidal waves with gravity. Tidal horizontal force (and with other external any kind of wind forces) on a floating object can be opposed by anchor it properly (by using minimum of four horizontal/ long-distance anchors) so that the vertical force remains almost the same. This vertical force is useful and it can be very much useful as easily increase this vertical force by Archimedes Principle (by increasing the size of the object). This bidirectional vertical force is very much suitable for pumping purposes. By installing pumps inside the ship, using the vertical bidirectional force of the wave and gravity on an anchored floating object continuously sufficient water pumping is possible for hydropower station and or desalination. This is a very easy technique to harness energy from ocean tidal energy as already running some small projects. Capacity can be increased as required by the Archimedes Principle. Expensive waterproof devices are not required, compared to the existing hydropower stations dam, big reservoir, big catchment area not required so cost-effective, also no need to think about the related problems like obstructing fish migration, changing river flow characteristics, affect on ecology, problems on important natural areas, agricultural land, relocation of people, etc.
For details visit:
https://www.scitechnol.com/peer-review/wave-energy-efficient-conversion-of-the-big-waves-vQFe.php?article_id=20138
2 my paper 28.0422 updating.docx
document - 3.11 MB - 04/28/2022 at 20:28
Download
The vertical force of Tidal waves is pumping water into the reservoir.
Portable Network Graphics (PNG) - 1.10 MB - 04/28/2022 at 19:32
Preview
  • 1 × Ocean [Waves] Unlimited source of energy.
  • 4 × Ships
  • 16 × Pump Piston Mechanism [placed inside the ships]
  • 10 × Anchor Mechanism
  • 1 × Pipes [as required]
View all 7 components
View project log
  • 1
    Idea stage
    Idea stage
View all instructions
Md. Moniruzzaman wrote 12/23/2022 at 13:56 point
I am happy to inform you that my idea has received a small recognition.
https://www.entrepreneurship-campus.org/ideas/34/21604/
Md. Moniruzzaman wrote 04/30/2022 at 20:11 point
#WaveEnergy is unique because it is the most concentrated form of renewable energy on earth, with power-density much higher than that of wind and solar energy.
Md. Moniruzzaman wrote 04/30/2022 at 20:07 point
#WaveEnergy
The Earth itself puts the source in our hands to address the energy crisis.
Considering the open space available in the ocean, and the tremendous amount of energy it produces, wave power could be a viable source of efficient renewable energy.
