The most suitable application for a round display is a programmable watch.
Using the GFX Library for Arduino (https://github.com/moononournation/Arduino_GFX) , we can easily configure and start using the round LCD, printing text and image on the display and playing animation.
What's best, the AMB23 dev board comes with built-in audio codec and an on-board audio jack for WAV audio data playing, so we can record a voice message and convert it to WAV, put it on the SD card then play the voice message at the designated time.
Here is the code,
Arduino Watch Lite Version
You may find full version at: https://github.com/moononournation/ArduinoWatch
* Start of Arduino_GFX setting
* Arduino_GFX try to find the settings depends on selected board in Arduino IDE
* Or you can define the display dev kit not in the board list
* Defalult pin list for non display dev kit:
* ESP32 various dev board : TFT_CS: 5, TFT_DC: 27, TFT_RST: 33, TFT_BL: 22
* ESP8266 various dev board : TFT_CS: 15, TFT_DC: 4, TFT_RST: 2, TFT_BL: 5
* RTL872x various dev board : TFT_CS: 12, TFT_DC: 14, TFT_RST: 15, TFT_BL: 13, VCC: 3V3, GND: GND, SDA: MOSI, SCL: CLK
* Go to Arduino_GFX_Library.h and update the TFT misc pins according to the definitions listed below
* #elif defined(RTL8722DM)
#define TFT_CS 12
#define TFT_DC 14
#define TFT_RST 15
#define TFT_BL 13
* Arduino Nano, Micro and more: TFT_CS: 9, TFT_DC: 8, TFT_RST: 7, TFT_BL: 6
#include <Arduino_GFX_Library.h>
/* More dev device declaration: https://github.com/moononournation/Arduino_GFX/wiki/Dev-Device-Declaration */
#if defined(DISPLAY_DEV_KIT)
Arduino_GFX *gfx = create_default_Arduino_GFX();
#else /* !defined(DISPLAY_DEV_KIT) */
/* More data bus class: https://github.com/moononournation/Arduino_GFX/wiki/Data-Bus-Class */
Arduino_DataBus *bus = create_default_Arduino_DataBus();
/* More display class: https://github.com/moononournation/Arduino_GFX/wiki/Display-Class */
//Arduino_GFX *gfx = new Arduino_ILI9341(bus, TFT_RST, 0 /* rotation */);
Arduino_GFX *gfx = new Arduino_GC9A01(bus, 15 /* RST */, 0 /* rotation */, true /* IPS */);
#endif /* !defined(DISPLAY_DEV_KIT) */
* End of Arduino_GFX setting
#define BACKGROUND BLACK
#define MARK_COLOR WHITE
#define SUBMARK_COLOR DARKGREY // LIGHTGREY
#define HOUR_COLOR WHITE
#define MINUTE_COLOR BLUE // LIGHTGREY
#define SECOND_COLOR RED
#define SIXTIETH 0.016666667
#define TWELFTH 0.08333333
#define SIXTIETH_RADIAN 0.10471976
#define TWELFTH_RADIAN 0.52359878
#define RIGHT_ANGLE_RADIAN 1.5707963
/////////////////// Audio Setting ////////////////////////
#include "FatFs_SD.h"
#include "PlaybackWav.h"
#include "AudioCodec.h"
char filename[] = "Time_Audio_16khz_16bit_Mono.wav";
#define BUFFERSIZE 512
int16_t buffer[BUFFERSIZE] = {0};
FatFsSD fs;
PlaybackWav playWav;
// Callback function to feed audio codec with additional data
void writeCBFunc() {
if(Codec.writeAvaliable()) {
playWav.readAudioData(buffer, BUFFERSIZE);
Codec.writeDataPage(buffer, BUFFERSIZE);
int playWavTime;
static uint8_t conv2d(const char *p)
uint8_t v = 0;
return (10 * (*p - '0')) + (*++p - '0');
static int16_t w, h, center;
static int16_t hHandLen, mHandLen, sHandLen, markLen;
static float sdeg, mdeg, hdeg;
static int16_t osx = 0, osy = 0, omx = 0, omy = 0, ohx = 0, ohy = 0; // Saved H, M, S x & y coords
static int16_t nsx, nsy, nmx, nmy, nhx, nhy; // H, M, S x & y coords
static int16_t xMin, yMin, xMax, yMax; // redraw range
static int16_t hh, mm, ss;
static unsigned long targetTime; // next action time
static int16_t *cached_points;
static uint16_t cached_points_idx = 0;
static int16_t *last_cached_point;
void setup(void)
// audio setting
Serial.begin(115200);
char absolute_filename[128];
fs.begin();
sprintf(absolute_filename, "%s%s", fs.getRootPath(), filename);
playWav.openFile(absolute_filename);
// GUI setting
gfx->begin();
gfx->fillScreen(BACKGROUND);
#ifdef TFT_BL
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, HIGH);
#endif
// init LCD constant
w = gfx->width();
h = gfx->height();
if (w < h)
center = w / 2;
else
center = h / 2;
hHandLen = center * 3 / 8;
mHandLen = center * 2 / 3;
sHandLen = center * 5 / 6;
markLen = sHandLen / 6;
cached_points = (int16_t *)malloc((hHandLen + 1 + mHandLen + 1 + sHandLen + 1) * 2 * 2);
// Draw 60 clock marks
draw_round_clock_mark(
// draw_square_clock_mark(
center - markLen, center,
center - (markLen * 2 / 3), center,
center - (markLen / 2), center);
// set time yourself, or you can use __TIME__ which is the compilation time stamp
const char ameba_time[] = "01:59:50";
hh = conv2d(ameba_time);
mm = conv2d(ameba_time + 3);
ss = conv2d(ameba_time + 6);
gfx->setCursor(90, 180);
gfx->setTextColor(WHITE);
//gfx->setTextSize(2,2,0);
gfx->println("Ameba Watch");
targetTime = ((millis() / 1000) + 1) * 1000;
playWavTime = millis();
char flag = 1;
void loop()
unsigned long cur_millis = millis();
if ((cur_millis > (playWavTime + 10000)) && (flag == 1)){
//Play wav file
Codec.setSampleRate(playWav.getSampleRate());
Codec.setChannelCount(playWav.getChannelCount());
Codec.setBitDepth(playWav.getBitDepth());
Codec.setWriteCallback(writeCBFunc);
Codec.begin(FALSE, TRUE);
flag = 0;
if (cur_millis >= targetTime)
targetTime += 1000;
ss++; // Advance second
if (ss == 60)
ss = 0;
mm++; // Advance minute
if (mm > 59)
mm = 0;
hh++; // Advance hour
if (hh > 23)
hh = 0;
// Pre-compute hand degrees, x & y coords for a fast screen update
sdeg = SIXTIETH_RADIAN * ((0.001 * (cur_millis % 1000)) + ss); // 0-59 (includes millis)
nsx = cos(sdeg - RIGHT_ANGLE_RADIAN) * sHandLen + center;
nsy = sin(sdeg - RIGHT_ANGLE_RADIAN) * sHandLen + center;
if ((nsx != osx) || (nsy != osy))
mdeg = (SIXTIETH * sdeg) + (SIXTIETH_RADIAN * mm); // 0-59 (includes seconds)
hdeg = (TWELFTH * mdeg) + (TWELFTH_RADIAN * hh); // 0-11 (includes minutes)
mdeg -= RIGHT_ANGLE_RADIAN;
hdeg -= RIGHT_ANGLE_RADIAN;
nmx = cos(mdeg) * mHandLen + center;
nmy = sin(mdeg) * mHandLen + center;
nhx = cos(hdeg) * hHandLen + center;
nhy = sin(hdeg) * hHandLen + center;
// redraw hands
redraw_hands_cached_draw_and_erase();
ohx = nhx;
ohy = nhy;
omx = nmx;
omy = nmy;
osx = nsx;
osy = nsy;
delay(1);
void draw_round_clock_mark(int16_t innerR1, int16_t outerR1, int16_t innerR2, int16_t outerR2, int16_t innerR3, int16_t outerR3)
float x, y;
int16_t x0, x1, y0, y1, innerR, outerR;
uint16_t c;
for (uint8_t i = 0; i < 60; i++)
if ((i % 15) == 0)
innerR = innerR1;
outerR = outerR1;
c = MARK_COLOR;
else if ((i % 5) == 0)
innerR = innerR2;
outerR = outerR2;
c = MARK_COLOR;
else
innerR = innerR3;
outerR = outerR3;
c = SUBMARK_COLOR;
mdeg = (SIXTIETH_RADIAN * i) - RIGHT_ANGLE_RADIAN;
x = cos(mdeg);
y = sin(mdeg);
x0 = x * outerR + center;
y0 = y * outerR + center;
x1 = x * innerR + center;
y1 = y * innerR + center;
gfx->drawLine(x0, y0, x1, y1, c);
void draw_square_clock_mark(int16_t innerR1, int16_t outerR1, int16_t innerR2, int16_t outerR2, int16_t innerR3, int16_t outerR3)
float x, y;
uint16_t c;
if ((i % 15) == 0)
innerR = innerR1;
outerR = outerR1;
c = MARK_COLOR;
innerR = innerR2;
outerR = outerR2;
c = MARK_COLOR;
else
innerR = innerR3;
outerR = outerR3;
c = SUBMARK_COLOR;
if ((i >= 53) || (i < 8))
x = tan(SIXTIETH_RADIAN * i);
x0 = center + (x * outerR);
y0 = center + (1 - outerR);
x1 = center + (x * innerR);
y1 = center + (1 - innerR);
else if (i < 23)
y = tan((SIXTIETH_RADIAN * i) - RIGHT_ANGLE_RADIAN);
x0 = center + (outerR);
y0 = center + (y * outerR);
x1 = center + (innerR);
y1 = center + (y * innerR);
else if (i < 38)
x0 = center - (x * outerR);
y0 = center + (outerR);
x1 = center - (x * innerR);
y1 = center + (innerR);
else if (i < 53)
x0 = center + (1 - outerR);
y0 = center - (y * outerR);
x1 = center + (1 - innerR);
y1 = center - (y * innerR);
void redraw_hands_cached_draw_and_erase()
gfx->startWrite();
draw_and_erase_cached_line(center, center, nsx, nsy, SECOND_COLOR, cached_points, sHandLen + 1, false, false);
draw_and_erase_cached_line(center, center, nhx, nhy, HOUR_COLOR, cached_points + ((sHandLen + 1) * 2), hHandLen + 1, true, false);
draw_and_erase_cached_line(center, center, nmx, nmy, MINUTE_COLOR, cached_points + ((sHandLen + 1 + hHandLen + 1) * 2), mHandLen + 1, true, true);
gfx->endWrite();
void draw_and_erase_cached_line(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t color, int16_t *cache, int16_t cache_len, bool cross_check_second, bool cross_check_hour)
#if defined(ESP8266)
yield();
#endif
bool steep = _diff(y1, y0) > _diff(x1, x0);
if (steep)
_swap_int16_t(x0, y0);
_swap_int16_t(x1, y1);
int16_t dx, dy;
dx = _diff(x1, x0);
dy = _diff(y1, y0);
int16_t err = dx / 2;
int8_t xstep = (x0 < x1) ? 1 : -1;
int8_t ystep = (y0 < y1) ? 1 : -1;
x1 += xstep;
int16_t x, y, ox, oy;
for (uint16_t i = 0; i <= dx; i++)
if (steep)
x = y0;
y = x0;
else
x = x0;
y = y0;
ox = *(cache + (i * 2));
oy = *(cache + (i * 2) + 1);
if ((x == ox) && (y == oy))
if (cross_check_second || cross_check_hour)
write_cache_pixel(x, y, color, cross_check_second, cross_check_hour);
else
if ((ox > 0) || (oy > 0))
write_cache_pixel(ox, oy, BACKGROUND, cross_check_second, cross_check_hour);
*(cache + (i * 2)) = x;
*(cache + (i * 2) + 1) = y;
if (err < dy)
y0 += ystep;
err += dx;
err -= dy;
x0 += xstep;
for (uint16_t i = dx + 1; i < cache_len; i++)
*(cache + (i * 2)) = 0;
*(cache + (i * 2) + 1) = 0;
void write_cache_pixel(int16_t x, int16_t y, int16_t color, bool cross_check_second, bool cross_check_hour)
int16_t *cache = cached_points;
if (cross_check_second)
for (uint16_t i = 0; i <= sHandLen; i++)
if ((x == *(cache++)) && (y == *(cache)))
return;
cache++;
if (cross_check_hour)
cache = cached_points + ((sHandLen + 1) * 2);
for (uint16_t i = 0; i <= hHandLen; i++)
return;
cache++;
gfx->writePixel(x, y, color);
More can be added, for example Alert message over BLE, more fluid animation and etc.
SimonXi
