Just a quick update on the firmware side of things. The latest version changed the serial commands a little bit. There are now descriptions with all the commands when you type 'help', which is a feature I wanted to include for a long time now.
On top of that the trailing ' - ' character is no longer needed for command parameters. In the past you would type e.g. 'set display -disable', now you only have to type 'set display disable'!
All the commands that expect additional arguments are highlighted with '< ... >' next to them.
> help
Usage:
<command> [options]
Commands:
read spectrum : Read the spectrum histogram collected since the last reset.
read settings : Read the current settings (file).
read info : Read misc info about the firmware and state of the device.
read fs : Read misc info about the used filesystem.
set trng : <toggle> Either 'enable' or 'disable' to enable/disable the true random number generator output.
set display : <toggle> Either 'enable' or 'disable' to enable or force disable OLED support.
set mode : <mode> Either 'geiger' or 'energy' to disable or enable energy measurements. Geiger mode only counts cps, but has ~3x higher saturation.
set int : <mode> Either 'events', 'spectrum' or 'disable'. 'events' prints events as they arrive, 'spectrum' prints the accumulated histogram.
set reset : <toggle> Either 'enable' or 'disable' for periodic resets of the P&H circuit. Helps with mains interference to the cap, but adds ~4 ms dead time.
set averaging : <number> Number of ADC averages for each energy measurement. Takes ints, minimum is 1.
set delay : <number> Delay between trigger and ADC readout of pulses in µs. Set this to ~1/2 of the maximum pulse duration you are expecting. Minimum is 1.
clear spectrum : Clear the on-board spectrum hist.
clear settings : Clear all the settings and revert them back to default values.
reboot : Reboot the device.
