![](https://cdn.hackaday.io/images/2599361651550798690.jpg)
![](https://cdn.hackaday.io/images/9975781651550816823.jpg)
![](https://cdn.hackaday.io/images/8066871651550831872.jpg)
![](https://cdn.hackaday.io/images/9685261651550851078.jpg)
Before first use, charge the battery by placing the bottle lamps in bright sunlight for at least a day. Then turn on the button switch to set the desired brightness ( Low / High ). Place the bottle lamp at the desired location like a garden or pathways. The solar lamp will be automatically switched on when the sun goes down.
If you want to use this lamp for lighting the room, you can follow this Instructables to mount it on the roof.
