![](https://cdn.hackaday.io/images/8813111652294467956.jpg)
![](https://cdn.hackaday.io/images/3176511652294468199.jpg)
![](https://cdn.hackaday.io/images/4907221652294468163.jpg)
Installed the PCB and all other external components as I have done in my earlier version. One change is that instead of directly soldering the terminal wires to the PCB, I have used JST PH2.0 connectors.
It will be easier for users and the connection is far better than the direct soldering. There will be no chance of short circuits and loose connections.
