I am going to use a 5-pin switch with has 4 modes of operations as shown in the above image. By using this switch I will be able to operate the LED in the following modes:
Mode-1: ON - High Intensity
Mode-2: ON - Medium Intensity
Mode-3: ON - Low Intensity
Mode-4: OFF - Turn Off the LED
Earlier I have used a 3-pin button switch for 3 different modes of operation as given below.
Mode-2: ON - Low Intensity
Mode-3: OFF - Turn Off the LED
Open Green Energy
