So i have a larger problem where my Solar Mppt charger won't work with both solar panels if the battery voltage is to low, its only rated for 360w when using a 12v system. So thats why i haven't updated in a bit and have been putting the project on bit of a hold until i get some funds to acquire a 48 volt system for energy storage. I have been doing some other projects on the side such as assembling a mobile weather station instead.
Corsix
