Case and LED module tests
A project log for Multispectral imaging smartphone camera
A smartphone imaging system for art conservation analysis
sean-billupsSean Billups • 06/28/2022 at 00:58•0 Comments
I've been working on modeling a case to include the filter wheel, removable LED light panels, and a tripod mount. It's been a slow process because I've had to learn Fusion 360 for this project.
But I finally got the first test prints, and it's all fitting together better than I had expected for a first go around.
                                                 Mounted on a tripod, with LED module.
                                   I only have white LEDs wired up, but next is UV and IR LEDs.
