Testing LED light modules
A project log for Multispectral imaging smartphone camera
A smartphone imaging system for art conservation analysis
sean-billupsSean Billups • 10/22/2022 at 12:31•0 Comments
Got to test out the LED modules. I made a UV (365nm) and an IR (850nm) module, both of which serve different purposes and enable different types of analysis.
The IR and UV light modules snap onto the magnetic back and plug into the USB port.
UV fluorescence, showing optical brighteners in the paper.
