Got to test out the LED modules. I made a UV (365nm) and an IR (850nm) module, both of which serve different purposes and enable different types of analysis.
The IR and UV light modules snap onto the magnetic back and plug into the USB port.
UV fluorescence, showing optical brighteners in the paper.
Sean Billups
