How It Works
When you are ready to putt, press the button on the handle of the putter. An accelerometer onboard the Arduino Nano 33 IoT will begin recording measurements during the swing. After the putt, an RGB LED on the head of the putter will give feedback -- a green light indicates that your form closely resembled that of the pro golfer that the putter was trained to recognize; red means that your technique was off.
In order for the putter to recognize proper putting technique, a K-means clustering algorithm (for anomaly detection) was trained on a set of accelerometer data collected from an instrumented putter. Ideally, this data would be collected from a professional golfer over time, such that there is enough data to perfectly characterize the putting technique that makes that golfer great. By loading a model trained with that data onto a Golf Ace putter, it would allow enthusiasts to buy a club that teaches them to putt like their favorite pro.
But, since there are no pro golfers that owe me a favor, for this prototype, I stood in as the "pro" that supplied the model training data. I am, after all, a winner of the GrandMaster Tournament of Champions Invitational minigolf tournament (which may or may not have been invented by myself and a few friends), so that should suffice for the occasion. To simplify building/training/deploying the anomaly detection model, I used Edge Impulse (public project here).
The Arduino sketch, which handles accelerometer data collection, machine learning model inferences, the RGB LED, and button presses can be found here.
One limitation of this device is that it is only capable of telling you if you have your technique right or not. It cannot tell you what you need to do differently. I envision a putter like this coming packaged with a video and/or written instructions from the golfer it was trained by to explain their technique. Then one could use that as the target they are working towards, with the putter offering feedback as to whether or not the target is being met.
Media
Bill of Materials
- 1 x Arduino Nano 33 IoT
- 1 x 4-pin 5050 RGB LED
- 1 x 3.7V to 5.0V power boost converter
- 1 x 400 mAh LiPo battery
- 1 x Micro USB breakout board
- 1 x Pushbutton
- 1 x Golf putter
- Miscellaneous wire
About the Author
Nick Bild
Zack Freedman
José Miguel Díaz
alex.miller
Sridhar Rajagopal
Wow, very nice I like it. This is very amazing for me. I appreciate that you have made this putter with very high and best technology. I like this model very much. You must have really worked hard on this. I am working on similar putter project (https://golfflipper.com/best-odyssey-putters/). I am collecting information about it. I like your product very much, it deserves praise.
