What about connectors you say.
Well for SMD ones I do not see an issue.
For THP connectors and or components I know from experience that you can make the drill holes tight enough that you don't need to solder.
Push the component lead into the tight hole in the PCB and the contact is good to go.
Alain d'Espaignet
