336 dots give more than 2500 components, I admit it start to be 'not-so-cheap'. Lets solder !
![](https://cdn.hackaday.io/images/723511613654081974.jpg)
![](https://cdn.hackaday.io/images/4539871613654122685.jpg)
An aluminium plat will make a good support
![](https://cdn.hackaday.io/images/4117611613654273595.jpg)
I used jumpers to link the power and SPI lines between the boards.
![](https://cdn.hackaday.io/images/6848801613654355372.jpg)
Then I played a bit with ESP32 and socket communication over Wifi. I have then a program on a computer that sends video frames packets on this socket.
I've put the kicad and code here : https://github.com/pierre-muth/fast-flipdot
Wow that's awesome! I've been checking in on this project from time to time, well done. You were featured in the hackaday email!
