Thermal Flask that senses the inside temperature and sends the information to a receiver via Bluetooth.
In this tutorial, I'm going to show you how to transfer the sensor readings between two ESP32 Boards via Bluetooth protocol.
Things that you need:
You must check out PCBWAY for ordering PCBs online for cheap!
You get 10 good-quality PCBs manufactured and shipped to your doorstep for cheap. You will also get a discount on shipping on your first order. Upload your Gerber files onto PCBWAY to get them manufactured with good quality and quick turnaround time. PCBWay now could provide a complete product solution, from design to enclosure production. Check out their online Gerber viewer function. With reward points, you can get free stuff from their gift shop.
M5StickC is a mini M5Stack, powered by ESP32. It is a portable, easy-to-use, open source, IoT development board. What it can do? This tiny block is able to realize your idea, enlighten your creativity, and help with your IoT prototyping in a very short time. It will take away a lot of pains from the development process.M5stickC is one of the core devices in M5Stack product series.
It is built in a continually growing hardware and software ecosystem. It has a lot of compatible modules and units, as well as the open source code & engineering communities that will help you maximize your benefits in every step of the developing process.
-------------------------------------------->Buy Link<----------------------------------------------------
Power switch operation:
Power on :Press power button for 2 seconds
Power off :Press power button for 6 seconds
Notice:
Compatible with multi-platform development:
