DIY-Calculator-using-Arduino
Performing simple mathematical operations was the basis on which one of the first computing machines designed by Charles Babbage who is considered as the father of computers was a steam-driven machine used to compute tables of numbers.
In this tutorial, we will build our own simple calculator using an Arduino and 4×4 keypad and display the result on a 16×2 dot matrix LCD Screen. Our calculator will be able to perform Addition, Subtraction, Multiplication, and Division. If you want to create your own mathematical function, you can do the same.
Just play around with the program and you will understand.
COMPONENTS REQUIRED
Breadboard
Arduino Uno
Arduino Uno Programming Cable
4×4 Keypad
16×2 LCD Screen
Jumper Wires
10kΩ Potentiometer
CIRCUIT DIAGRAM
In this diagram, we can see that there are eight pins coming out of the 4×4 Keypad. It has 4 pins for rows and 4 pins for columns.
These 8 PINS are driven out from 16 buttons present in the MODULE. Those 16 alphanumeric digits on the MODULE surface are the 16 buttons arranged in MATRIX formation. These are mostly used for the control system or embedded systems where we need to give some command to the system to perform a given task
or when we need to perform multiple tasks but with a smaller number of pins.
Understanding how 4×4 Keypad works is a little tricky. The module only has 8 pins to interface 16 buttons. To understand consider we have connected the pad to a microcontroller now set all the rows to output and set them logic HIGH that is 5V.
Now set all the columns to INPUT to make them sense logic HIGH.
Now as the key is pressed at ROW 3 and COLUMN 2, the current flows as shown in the figure. As all Columns are inputs sensing high, so controller sense that logic HIGH is present at C2 pin and store it in its memory that button pressed is in Column 2.
Now all Column pins are set HIGH and all Rows pin are set as INPUT to sense the incoming logic HIGH.
Now the current flows as shown in the figure and Microcontroller sense that Pin R3 is getting Logic High, so button pressed is in Row 3 and it knew that button is in Column 2 from earlier settings. So in this way, the controller senses which key is being pressed on the keypad.
ARDUINO CODE EXPLANATION
First, you have to make sure that you have the necessary libraries installed in your Arduino IDE from the links given below-
For LCD screen library see https://www.arduino.cc/en/Reference/LiquidCrystal
For 4*4 Keypad Library download from https://github.com/Chris--A/Keypad
Start the code by including the libraries in the code and then define the keys on the pad. Put in the pins, the Keypad and LCD screen is connected to. Create the keypad variable, so that you don’t have to deal with the identification process of the pressed key, let the library take care of it.
#include <LiquidCrystal.h>
#include <Keypad.h> // Download library for Keypad from https://github.com/Chris--A/Keypad
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
}; // defining the keys in the keypad
byte rowPins[ROWS] = { 2, 3, 4, 5 };
byte colPins[COLS] = { 6, 7, 8, 9 };
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
Now initialize the serial monitor and start giving the inputs from the keypad to the Arduino. The functions defined in the code will take the input and display the result on the LCD screen. Make sure that you press the ‘#’ button to get the result after pressing the numbers and operand.
The arithmetical operations will be performed by-
Character on Keypad
Assumed to be
‘A’
Addition (+)
‘B’
Subtraction (-)
‘C’
Multiplication (*)
‘D’
Division (/)
Clear (C)
Equals (=)
The final result will be updated in the second line of the LCD screen as shown and given by the following code-
void DisplayResult()
lcd.setCursor(0, 0); // set the cursor to column 0, line 1
lcd.print(Num1); lcd.print(action); lcd.print(Num2); // Display the result on LCD Screen
Serial.println();
Serial.println(Num1); Serial.print(action); Serial.print(Num2); // Display the result on Serial Monitor
if (result==true)
//{lcd.print(" ="); lcd.print(Number);} //Display the result
Serial.print(" = "); Serial.print(Number);
lcd.setCursor(0, 1); // set the cursor to column 0, line 1
lcd.print(Number); //Display the result
// delay(1000); change this to suit your needs
Before moving fuurther I would like to tell you something about PCB
Yes PCB are the heart of the electronics based project usually we hesitate to try custom PCB and opt to homemade solutions
like breadboard or Zero PCB earlier I also was in the same boat, I hesitate to try custom PCB my belief was they are much expensive.
but then I came to know about JLCPCB.COM and I was totally surprised how low price PCB's are they offering
there PCB quality is best in market, now I always go with PCB for my project and JLCPCB.COM is my trusted
If you planing to order any PCB for your projects so you can consider JLCPCB.com because
I always prefer JLCPCB.com for my PCB needs, JLCPCB.com have best deals for their customers $2 for 1-4 Layer PCBs, free SMT assembly monthly.
If you seriously need quality PCB quickly in your hand then you must have to try JLCPCB PCB manufacturing service. They have Special offer of $2 for 1-4 Layer PCBs, free SMT assembly monthly. If new user signup today from this link JLCPCB.com you will get welcome coupons from JLCPCB.
SMT Assembly service of JLCPCB.com is cherry on top now get your PCB fully assembled and save your time and money Select components for your PCB from there Parts Library of 200k+ in-stock components they are offering $30 valued New User coupons & $24 SMT coupons every month $8.00 setup fee, and $0.0017 per joint
Now no need to order components separately for you PCB and get free from stress of soldering them on PCB just try PCB SMT assembly service and get you PCB with components pre assembled and ready for the project
👉 Try PCBA service of JLCPCB.com and save your time and money, get PCB ready for project, 200K+ components in library of JLCPCB.com as well as 3rd party parts to choose from. Assembly will support 10M+ parts from Digikey, mouser
👉 $30 valued New User coupons
👉 $24 SMT coupons every month
For more detials & offers please visit JLCPCB.com
ARDUINO CALCULATOR CODE
#include <LiquidCrystal.h> //See the functions and commands in library for LCD screen from this url https://www.arduino.cc/en/Reference/LiquidCrystal #include <Keypad.h> // Download library for Keypad from https://github.com/Chris--A/Keypad const byte ROWS = 4; // Four rows const byte COLS = 4; // Four columns as this is a 4*4 Keypad char keys[ROWS][COLS] = { {'1','2','3','A'}, {'4','5','6','B'}, {'7','8','9','C'}, {'*','0','#','D'} }; // defining the keys in the keypad byte rowPins[ROWS] = { 2, 3, 4, 5 };// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins. byte colPins[COLS] = { 6, 7, 8, 9 }; // Connect keypad COL0, COL1, COL2 and COL3 to these Arduino pins. Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS ); // Create the Keypad variable to identify and store the pressed key. const int rs = A0, en = A1, d4 = 10, d5 = 11, d6 = 12, d7 = 13; //Pins to which LCD is connected LiquidCrystal lcd(rs, en, d4, d5, d6, d7); long Num1,Num2,Number; // defining the variables for the operations char key,action; boolean result = false; // boolean variable so that we display the result whenever its available void setup() { lcd.begin(16, 2); //We are using a 16*2 LCD display lcd.print("4*4 Calculator"); //Display a intro message lcd.setCursor(0, 1); // set the cursor to column 0, line 1 lcd.print("Quartz Components"); //Display a intro message Serial.begin(9600); // Initialise the serial communication Serial.println("Ready to initiate"); // for displaying on serial monitor delay(3000); //Wait for display to show info lcd.clear(); //Then clean it } void loop() { key = kpd.getKey(); // for storing pressed key value in a character variable (char) if (key!=NO_KEY) DetectButtons(); // Identify which button is being pressed and work accordingly if (result==true) CalculateResult(); // If the result needs to be calculated then this function will take care of it DisplayResult(); // Display the obtained result on the Display or serial monitor } void DetectButtons() { lcd.clear(); // First clear the LCD if (key=='*') //If cancel Button is pressed perform the below mentioned equation or function {Serial.println ("Button Cancel"); Number=Num1=Num2=0; result=false;} if (key == '1') //If Button 1 is pressed {Serial.println ("Button 1"); if (Number==0) Number=1; else Number = (Number*10) + 1; // Perform this if the button is Pressed twice } if (key == '4') //If Button 4 is pressed {Serial.println ("Button 4"); if (Number==0) Number=4; else Number = (Number*10) + 4; // Perform this if the button is Pressed twice } if (key == '7') //If Button 7 is pressed {Serial.println ("Button 7"); if (Number==0) Number=7; else Number = (Number*10) + 7; // Perform this if the button is Pressed twice } if (key == '0') {Serial.println ("Button 0"); //Button 0 is Pressed if (Number==0) Number=0; else Number = (Number*10) + 0; // Perform this if the button is Pressed twice } if (key == '2') //Button 2 is Pressed {Serial.println ("Button 2"); if (Number==0) Number=2; else Number = (Number*10) + 2; // Perform this if the button is Pressed twice } if (key == '5') {Serial.println ("Button 5"); if (Number==0) Number=5; else Number = (Number*10) + 5; //Pressed twice } if (key == '8') {Serial.println ("Button 8"); if (Number==0) Number=8; else Number = (Number*10) + 8; //Pressed twice } if (key == '#') {Serial.println ("Button Equal"); Num2=Number; result = true; } if (key == '3') {Serial.println ("Button 3"); if (Number==0) Number=3; else Number = (Number*10) + 3; //Pressed twice } if (key == '6') {Serial.println ("Button 6"); if (Number==0) Number=6; else Number = (Number*10) + 6; //Pressed twice } if (key == '9') {Serial.println ("Button 9"); if (Number==0) Number=9; else Number = (Number*10) + 9; //Pressed twice } if (key == 'A' || key == 'B' || key == 'C' || key == 'D') //Detecting Buttons on Column 4 { Num1 = Number; Number =0; if (key == 'A') {Serial.println ("Addition"); action = '+';} if (key == 'B') {Serial.println ("Subtraction"); action = '-'; } if (key == 'C') {Serial.println ("Multiplication"); action = '*';} if (key == 'D') {Serial.println ("Devesion"); action = '/';} delay(100); } } void CalculateResult() { if (action=='+') Number = Num1+Num2; if (action=='-') Number = Num1-Num2; if (action=='*') Number = Num1*Num2; if (action=='/') Number = Num1/Num2; } void DisplayResult() { lcd.setCursor(0, 0); // set the cursor to column 0, line 0 lcd.print(Num1); lcd.print(action); lcd.print(Num2); // Display the result on LCD Screen Serial.println(); Serial.println(Num1); Serial.print(action); Serial.print(Num2); // Display the result on Serial Monitor if (result==true) //{lcd.print(" ="); lcd.print(Number);} //Display the result Serial.print(" = "); Serial.print(Number); lcd.setCursor(0, 1); // set the cursor to column 0, line 1 lcd.print(Number); //Display the result // delay(1000); change this to suit your needs }
