Weirdly, at any current limit settings, the motor will start to spin, then stop. This works fine on the Cure mode (which worked fine on the A4988 too), however, the crucial Wash mode doesn't work. It only goes up to a certain speed, then stalls and vibrates. I tried everything and it's already 3AM, so I'll try again tomorrow.
