Another ATX Power Supply
My own take on converting an ATX power supply into a useful benchtop supply.
joeJoe
0 followers
This is my attempt at designing an all-purpose power supply from an ATX power supply that was otherwise destined for recycling. This was partially inspired by all the other projects on here doing this and from the video that DroneBot Workshop made on YouTube linked in the project.
  • 1 × Antec SL350 350W ATX Power Supply (20 Pin Connector)
  • 1 × Red LED Standard 5mm LED
  • 1 × Green LED Standard 5mm LED
  • 2 × 220 Ohm Resistors
  • 1 × 10 Ohm Power Resistor 50W 10 Ohm Power Resistor
View all 11 components
