Essentially I have three goals.
Remove everything from the Prius without damaging anything.
Reassemble everything on the floor and get the engine running outside of the chassis while removing as many systems as possible without upsetting the hybrid ECU.
Fabricate subframe mounts and put everything into the Corvair.
This is massively simplifying the amount of work involved.
Aong the way I will need to find a way to spoof the rear ABS sensors, as this current front engine front drive system will be occupying the rear of the Corvair, there will be nowhere for those old rear sensors to go.
The front and rear tone rings and sensors seem to be identical, I would like to find a way to take the front sensor signal, and repeat it to the rear inputs, this will both effectively disable ABS while keeping regenerative braking active, the hybrid ECU disables regenerative braking if any ABS codes are active.
Ryan
Rory
Joseph Demers
mauswerkz
Chris Low
This looks like a fun project!
