The can transformer can easily cut patterns in the can like this:
You can then pop a light source inside and use it as either a lamp or a personalised display like this:
When cutting a pattern you do have to be careful to use tabs to keep any areas that would otherwise fall out, like the triangular piece in the 'A' above.
