The OpenSCAD file that generates the can bottom holder is parametric so you can adjust the part to fit different can sizes and also to fine tune the print to your printer. There are several different can sizes, I have tried the standard UK 330ml can and also a smaller (150ml?) can, which also worked. The holders with smaller can bottoms take up less desk space.
