Trim Wheel Done
A project log for Speed Modeling A Cessna Controller for FS2020
My attempt to build a reasonable and fully usable Cessna throttle block in one day.
timo-birnscheinTimo Birnschein 05/28/2022 at 15:350 Comments
A 10 turn poti for a simple laser cut trim wheel
I also added nuts on the other side of all the mounts so that 5.5mm M3 nuts can be pressed into the holes to make mounting easier and more robust.
Rich text editor
