A 10 turn poti for a simple laser cut trim wheel
I also added nuts on the other side of all the mounts so that 5.5mm M3 nuts can be pressed into the holes to make mounting easier and more robust.
A project log for Speed Modeling A Cessna Controller for FS2020
My attempt to build a reasonable and fully usable Cessna throttle block in one day.
