Hackaday.io Hackaday.io
Sign up Log in
ATtiny424 Binary kitchen timer-internal clock
Testing out the ATtiny424 (new 2-series ATtiny) with internal oscillator.
sherman-stebbinsSherman Stebbins
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 0
View Gallery
203
0
0
0
Team (1)
  • sherman-stebbinsSherman Stebbins
Join this project's team
  • Schematics and code
  • Other projects
ongoing project
sherm sherman shermluge shermluge.com binary attiny 424 attiny424 timer Kitchen led 2-series
This project was created on 05/29/2022 and last updated 4 years ago.
Description
I wanted to create something useful from the ATtiny424 (new 2 - series). So I decided on a Binary Kitchen timer.
Even though the the new Series in ATtiny's internal 32768hz low power clock is not exactly accurate, I figured its close enough for a kitchen timer. This is now working, but still a work in progress. The version I have in the kitchen has performed without any flaws now for a couple of weeks. It sleeps after a few minutes if not used. When you hit Cancel button it also goes to sleep. Setting is easy. Just press and hold set button. It goes up to 15 min. (mainly because anything I cook the longest I go is 15 minutes till I at least check on it). It remembers what you last set it as. It will pause as well, but if paused to long it will go back to sleep.
Files
Graphics Interchange Format - 4.90 MB - 05/29/2022 at 21:40
Preview
Build Instructions
Collapse
  • 1
    Step 1
    Instructions at https://www.shermluge.com/electronics/attiny424/attiny424-binary-kitchen-timer-internal-clock
View all instructions
Log In/Sign up to comment
Sign up with Github
OR
A busy/free desktop indicator for the Adafruit Circuit Playground Express. Red shows you are busy and for how long, blue shows you are free!
Project Owner Contributor
Busy/Free Desk Indicator
deckeregoDeckerEgo
Clock that chimes on the hours, halves, quarters
Chiming Clock
scoopsScoops
Meet Reborn ZIN18 the new super-compact Nixie tube - is shape of the history in the strong and smart modern body.
ZIN18 - the new Nixie Tube & clocks
igorIgor
Setting up a new work space for electronics, metalworking, and the like
New House, New Shop
adam-fabioAdam Fabio
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ATtiny424 Binary kitchen timer-internal clock", please tell us the reason.
Send message
Remove Member
