Here you can see the first version of the solarPhalanx PCB.
This PCB contains all kind of light related sensors, with which the brightness, uv radiation values and even the alignment of the weather station can be determined.
Unfortunately, due to the current shortage of chips, not all sensors are available. But there are definitely enough left for a first test. :)
A first overview of the available components can be seen in the picture below.
