In the meantime I have also created the circuit board for the Anemosens sensors and completed the first tests.
A Hall sensor (for detecting the wind speed) and an AS5048B rotation angle sensor are located on the circuit board. With the latter, the direction of the wind can be determined.
As always, you can see more details in the pictures. :)
