While this project looks like it's complete, there are still a few things to do.
I am currently working on a simple 3D printable wind tunnel, which I want to use to calibrate "Anemosens" properly. So it should be possible to get a list of calibration values for the different wind speeds.
In addition, I am working on a new circuit board for the Anemosens MCU. With this it should be possible to evaluate the sensors from Anemosens even in battery operation and to be able to log or forward the data if necessary. The current board is not really suitable for this because the circuit is not optimized for battery operation. More information will follow as soon as I have finished the first draft. :)
