Made a quick proto board to give to the software/micro guy to play with.
Two motors on a small proto board, with an alerter. The alerter was an afterthought, and mostly because I had a bunch of them sitting around unused. I figure the alerter can be used in conjunction with the haptic feedback as an alert - when the ammo (or health) gets below a certain value, the alerter will beep. When the health gets critical, the beeper will beep continuously, and so on.
The user can easily distinguish an alert coming from their forearm instead of the computer, so this should add to the haptic experience.
Note: Laser cutter goes through perfboard very well.
Peter Walsh
