Read the complete update if you're a patient human being.
Progress Overview
- Hardware
- Most essential components are verified working
- There are some difficulties with RF sections
- The v3.0 PCB is being designed
- Introduced the idea of “accessories”
- Software
- Minor tweaks of the Linux kernel configuration
- Investigation of the suspend-to-RAM process is started
- Fundraising
- This project is accepted by Crowd Supply
- We’re negotiating with them
PCB version 3.0 ChangeLog
- Removed: GNSS section
- a quad protocol GNSS receiver BLE accessory will be available
- Removed: LoRa spring antenna
- will revert to Nokia 168x’s original antenna with quad GSM bands
- a LoRa transceiver accessory with external antenna will be available
- Removed: internal 5MP AF camera
- an 13MP AF camera USB-C accessory will be available
- Added: built-in UART to Bluetooth for easier hacking
- Change: SPI NOR changed to W25Q512
- Bugfix: add power sequencing MOSFET to meet SD NAND’s VDD rise time requirement
- Bugfix: AP6214 Bluetooth needs 32.768kHz clock to work
- Bugfix: AP6214’s VBAT should be connected to VSYS, not 3V3, for better power efficiency
- Bugfix: More capacitance on 3V3 rail to prevent LCD backlight knocking out the BQ25895 without battery
