We finally finished integrating all of the components that go inside the box. We made sure they would all be of the proper measurements and manage the arrangement of the textures to make it visually appealing.
Due to the fact that the texture where about 3 cm long, we decided to put some foam in order to fill the free space between the bottom of the box and the actual texture to keep it light but functional.
To make it safe we manage to paste all of the components with hot glue and super glue to make sure they wouldn´t be able to take them out of the box.
At the end the colors turned out to be pleasing and the electronic part (LED ring) was working well. Because it had a battery inside we had to put some foam in it too so that it would have the proper height as each square.
