- water pump and 4 solenoid valves can be controlled via MQTT e.g. Home Assistant
- controller settings can be adjusted via web interface (available in German/English)
- offers simple stand-alone scheduler to water plants once a day
- ultrasonic sensor ensures minimal water level in reservoir
- only one valve can be opened at a time to maximize pressure on each dripping branch
- valves will switch off after preset time and then blocked to avoid accidental over-watering
- writes events and sensor readings to log file in ESP32 flash including log rotation
- creates a local access point for initial system setup or if no Wifi is available
- OTA firmware updates
