Hackaday.io Hackaday.io
Sign up Log in
Magic Stick (HID)
Using a Magic stick instead of a Mouse
jj
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
4 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 6
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
920
0
4
7
Team (2)
  • jj
  • foufounerfoufouner
Join this project's team
completed project
MISC
hid arduino
This project is submitted for
  • Odd Inputs and Peculiar Peripherals
This project was created on 06/05/2022 and last updated 4 years ago.
Description
Once upon a time i stumbled on the intriguing 2D HID sensor (human interface device) of the Nintendo Wii controller. I turned it into a input device functioning as a alternative for the mouse.
It is a IR camera with a nice resolution (128x96 pixel) recognizing the position up to 4 IR-emitters.
This camera sensor dose not take pictures, but it provides positions of all 4 possible IR-sources.
In the beginning i tried to convert 2 old Wii controllers into a stand alone sensor. I found somewhere some schematics, but i did not get any (SPI) signals.
After searching for alternatives i found the same sensor as a stand alone product.
If the sensor see's one IR emitter, this so called BLOP, gives the position of the mouse cursor. If a second BLOP appears, a left mouse click is triggert. The third BLOP triggers a right mouse click.
For a ego-shooter game i added a auto fire (fast click rate on left mouse button) and it was quite playable.
Details
Files
pvision.ino
Code
ino - 8.54 kB - 06/05/2022 at 12:12
Download
Components
  • 1 × Gravity: IR Positioning Camera For Arduino https://www.dfrobot.com/product-1088.html
  • 1 × Arduino DUE
  • 1 × 4 x IR Leds
  • 1 × coin cells
  • 1 × a Magic Stick
View all 6 components
Log In/Sign up to comment
Sign up with Github
OR
I also want to make a 6DOF mouse
Project Owner Contributor
One more 3D mouse
vedranVedran
Simple designs ideas that might prove useful
Design Ideas
michael-otooleMichael O'Toole
The 2018 Hackaday Prize
Compact, handheld air guitar with four LiDAR strings and Bluetooth
Litar: LiDAR Air Guitar
blair-wyattBlair Wyatt
An alternative version of the SONOFF SNZB-02 air temperature and humidity sensor from ITEAD
SONOFF SNZB-02 DIY
andrew-lamchenkoAndrew Lamchenko
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Magic Stick (HID)", please tell us the reason.
Send message
Remove Member
