Put the code pieces together. Made a ZIP file of the current build.
Status
- Menu is functional
- Menu structure
- Top Level
- File Send
- File Receive
- Config COM
- Sd Info
- SD Dir
- Tests
- Config COM
- Set Baud Rate
- Config Handshakes
- Tests
- Test LEDs
- Test Buttons
- Top Level
To Do
- SD Dir currently just displays a directory
- Needs to allow selection of file to transfer
land-boards.com
