Got menus working for the serial port configuration for:
- Baud rate
- Serial Protocol
- Handshake
Menus are all in place, but not all of the functions are created for the above. The baud rate select menu is working/tested and set to 9600 baud as default. Tested at 9600 baud and 300 baud.
Got UART transmit code working.
This is now a minimal viable product.
land-boards.com
