🚀 Introduction
ksIotFrameworkLib is an Arduino-based C++ framework designed for ESP32 and ESP8266 microcontrollers.
The library handles the typical IoT boilerplate for you - from initial Wi-Fi provisioning via a captive portal to MQTT connectivity with a robust reconnection mechanism. It also includes a built-in LAN-accessible web portal for device configuration, over-the-air firmware updates, live status monitoring, and terminal access.
The terminal, a special feature of the web portal, lets you view real-time application logs and define your own commands.
By handling these repetitive foundations, ksIotFrameworkLib lets you concentrate on the unique logic of your smart sensors, controllers, or DIY automations - without needing to reinvent connectivity or configuration layers every time.
💡 Potential use cases
🏠 Smart home solutions - services, monitoring, alarming
📊 Telemetry systems - sending sensor data, device statuses
🎛️ Remote control applications - switching devices, executing commands
The library is not limited to these examples - it’s designed to support a wide range of IoT projects.
For instance, one of my personal implementations involves remotely controlling a heating boiler, fully integrated with Home Assistant via MQTT. I have devices running continuously for months without interruptions, demonstrating the library’s stability and reliability in real-world deployments.
🧭 Motivation
Create a solid starting point for developing applications targeting Espressif microcontrollers
Streamline the process of adapting and reusing code across multiple devices
Apply the DRY principle (Don't Repeat Yourself) to DIY IoT projects by consolidating common functionality into a simple, reusable library
🛠️ How it started?
I first got into programming back in elementary school, but PCBs fascinated me even earlier. It started when my cousin showed me a small microphone board from a CB radio - and I couldn’t stop thinking about how such things were made. I always dreamed of creating my own.
The first real project happened years later when I modified my dad’s car radio so it powered on with the ignition. That little hack was the spark that led me to discover Arduino - and the urge to build something truly mine.
My first breadboard project was a pump controller for an old heating furnace. It turned on the pump automatically when the temperature was right. Looking back, I’m still surprised it worked! But that’s when I got hooked on real-time telemetry.
That was around 2017, using the ESP8266. As I built more devices, I noticed I was constantly duplicating code. So in 2020, I decided to create a lightweight framework that would unify my projects - and that’s how ksIotFrameworkLib was born.
Today, several of my devices use it daily, sending thousands of MQTT messages to control everything from Zigbee-based home automation to my parents’ heating boiler over CAN bus, connected through a cellular network.
The framework keeps evolving, driven by real-world use and the desire to make each next device easier to build than the last.
cziter15
hello42world
Roman V
Giulio Pons
