The first test print of the spool with resin didn't turn out so well. Lost a lot of the supports on the feeder, the lid failed completely. After chasing the threads with a die the feeder fit nicely with the spool holder. The spool holder still had the center hole sized for heat set insert. I tried to install one with extra heat but ended up splitting the mounting location.
Last time I used this resin was winter and space heaters were used to keep printer warm. Side project started to add a heater to the resin printer.
The spools turned out nicely.
