Integral spool testing
A project log for One Handed Manual Solder Feeder
A contraption to help feed solder efficiently single handed.
mulcmumulcmu 07/28/2023 at 23:460 Comments
Finally got some usable resin parts printed and cured for testing.  Works very nicely.  There is a bit of a trade off on size and weight of spool and balance in your hand while using it.  The spool could be mounted a bit closer to the ferrule or maybe a bit smaller in size to not be as heavy (at cost of more frequent refills).
Rich text editor
