here are the rough steps for building CircuitPython for the ESP32-S3 N8R8 devkit board:
git clone git@github.com:kmatch98/circuitpython.git
cd circuitpyton
git checkout esp32s3_dotclockdisplay
make fetch-submodules
# Also I had to do this, I’m not sure which step.
git submodule update --init --recursive
cd ports/espressif
# Note: When I get here, the esp-idf directory is created, but empty.
git clone git@github.com:kmatch98/esp-idf.git
git checkout rgb_add
cd ports/espressif/esp-idf
. ./export.sh
cd .. # move up to ports/espressif folder
make BOARD=espressif_esp32s3_devkitc_1_n8r8
I got this error:
ninja: Entering directory `build-espressif_esp32s3_devkitc_1_n8r8/esp-idf'
ninja: error: '../../esp-idf/components/esp_lcd/linker.lf', needed by 'esp-idf/esp_system/ld/sections.ld', missing and no known rule to make it
# So I had to copy over this linker.lf file from the repo to circuitpython/ports/espressif/esp-idf/components/esp_lcd:
[mapping:esp_lcd]
archive: libesp_lcd.a
entries:
if LCD_RGB_ISR_IRAM_SAFE = y:
esp_lcd_common: lcd_com_mount_dma_data (noflash)
esp_lcd_rgb_panel: lcd_rgb_panel_start_transmission (noflash)
# Then I reran:
pip install esptool
# Then I had to hold BOOT, tap RESET, release BOOT:
python3 -m esptool --chip esp32s3 write_flash 0x0 build-espressif_esp32s3_devkitc_1_n8r8/firmware.bin
kmatch98
