when the dongle is supplying data over wifi, the SDR seems to stall two or three times a minute. i don't know if this is a buffering problem on the server or client side or a wifi bandwidth problem. i am guessing it is the wifi because my network has a lot of devices on it. i am going to configure the router as an access point on its own network (and a different wifi channel) and see what that does. more to follow...
worsthorse
