![](https://cdn.hackaday.io/images/3342641655013756684.jpg)
![](https://cdn.hackaday.io/images/1854781655013807061.jpg)
![](https://cdn.hackaday.io/images/2746811655013808988.jpg)
![](https://cdn.hackaday.io/images/6533831655013809008.jpg)
Purity manifold. Top is moisture count in helium. Measured in Parts per million. Below is percent oxygen in the helium space. That reading should usually read 0.00. We had a really bad leak in the system.
![](https://cdn.hackaday.io/images/7977231655014161157.jpg)
A project log for Helium Recovery Recycling System
I manage a helium recovery system. Labs use liquid helium for their experiments and I recover that helium as gas and liquidfy it.
