Hackaday.io Hackaday.io
Sign up Log in
Plant Sensor node
Sensors node to monitor ambient light, temperature, humidity, noise and soil moisture. It can also drive a water pump and two grow LED strip
nathannNathann
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
278
0
1
0
Team (1)
  • nathannNathann
Join this project's team
hardware
ongoing project
plantcare Sensors LoRanode
This project was created on 06/14/2022 and last updated 4 years ago.
Description
# Feature
- ambiant humidity sensors and temperature (DHT11)
- soil humidity sensors (capacitive module with analog out)
- lux meter
- pressure sensor
- microhone (detect noise level + weather / rain / wind ?)
- 3 mosftet output, 2 LED strip + pump
- low power features, turn off every peripheral except ESP32 that can deepsleep and LoRa
- LoRa (433Mhz) (not compatible with TTN :( 868 Mhz is too expensive) , wifi and bluetooth connectivity
- buzzer to locate the sensors (and maybe repell some animal ?)
- GPS to track the sensors and have an accurate time base
- local data display on OLED screen or remote via the LoRa
- input voltage monitoring, get an idea of the battery left if powered by one
- 3 I2C port that can be repurposed for 3V3 peripheral
- 70 x 70 mm PCB but might shrink later
- 20-30 $ to produce. All component available at AliExpress
# TODO
- Write the firmware
- redraw the power trace for improved power
- build the board and test it
Project Logs
Collapse
  • PCB in production
    Nathann • 06/20/2022 at 15:40 • 0 comments
    PCB in production. check the github for the latest version of the board.
    i "just" have to write the firmware now
View project log
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Plant Sensor node", please tell us the reason.
Send message
Remove Member
