#define MOTOR1_KP_SHIFT 0 //kP = 1
#define MOTOR2_KP_SHIFT 3 //kP = 8
void pwmify(motor_t *motor)
//Assuming "power" is > 0 when moving toward desiredPos>0 from 0...
int32_t power = (motor->desiredPos - motor->actualPos);
//power *= (int32_t)(motor->kP); //!!!
//This ONE multiplication takes about 100us!
//Regardless of whether kP is 1 or 8
//Despite kP being 'const'
//And replacement reduces codesize by nearly 400B
// (Probably due to _mult_i32() not being linked in?)
//NOTE: The kP "multiplication" replacement
//is now handled after the following
//(Alternatively, I suppose, I could assume the desired/actual
// difference should never be greater than an int8_t...?)
if(power >= 0)
motor->dir = 1;
else
motor->dir = -1;
//unsign it!
power = -power;
uint32_t uPower = power;
//The kP multiplication is now replaced with this:
//NOTE: SIGNED-SHIFT is undefined per C's specs (as I recall)
// So this needs to be AFTER the sign is removed.
if(motor->num == 1)
uPower <<= MOTOR1_KP_SHIFT;
else
uPower <<= MOTOR2_KP_SHIFT;
if(uPower > 255)
uPower = 255;
motor->pwm = uPower;
Eric Hertz
Funny thing - on the XC8 PIC compiler - I dug around and found - guess what - the 32x32 multiply routines are written in C, not hand-optimized assembly code. I wonder of you are looking at a similar situation? I guess this makes sense because the PIC compiler targets so many different 8-bit targets, but still.
The upside is that I think I found somewhere I can optimize my code :-)
Interesting, indeed. I'll have to take a look at the output!
Can you have motor->dir = 0 ?
Dun see why not...
I haven't looked at this guy's instruction-set recently, but as I recall AVRs have Branch if Equal as well as Branch If Equal Or Greater, so I think it should compile to the same number of instructions, using -1 instead of 0. But that's quite an assumption, on my part.
What'd you have in mind?
Re Profiling: I'm sure there's a fancy way to do something like that, but I'm just toggling an LED between different function-calls. I also haven't yet looked into the assembly-output...
Is that what you meant by "profiling"?
Functionality-wise, I've been meaning to post an update... The feedback loop works as-expected, but I didn't expect a bunch of "real-world" effects that render this system a lot less-intuitive (usefulness-wise) than I'd hoped... So kinda back to the drawing-board.
400B for a mul32? That's almost half your allotment :-)
But wait - what uC is this on? I'm using mul32s on a mid-range PIC with the lousy free XC8, and they're not 400B.
Agree, this seems utterly shocking to me.
Consider GRBL, which uses *dozens* of such calculations in floating-point, no less.
This is an ATtiny861, I'm assuming it has no "mult" instruction... so maybe that's part of it.
OTOH, consider that I've used this same uC to do realtime 10-bit audio recording to an SD Card at 19.2KS/s, as I recall... Seems with all that overhead, *bit-banged* serial I/O, a bit-banged PS/2 keyboard, and an SPI LCD display...
Shocking, to say the least, I'm getting only 17000 loops/second, after the mult-replacement, on this tiny project.
Can you profile your code ?
