This is a capstone project for my engineering degree at UVic. The entire design process was limited to 3 months based on course requirements. 5 colleagues will be working with me throughout this design, and I’ll be leading the schematic and PCB design.
In general, I’ll be using these logs to document the hardware testing. Any posts that relate to work that is not my own will be credited as such. Once the project is completed, I will add relevant design documents and Gerber files.
