Python MicroService Bus for IoT
Python Peer to Peer MicroService Bus for IoT Messaging Framework
Latest work:
I am currently well along a personal project to build a simplified data-driven MicroService Bus in Python to integrate RPI HAN nodes, ESP IoT wifi devices., communicating freely with the world of telemetry and cloud messaging service capabilities (think ESB for the PI).
Key Objective: Single install sw to configure RPI/Linux as a Home Area Network. Harness all io capability I2C, 1-wire, GPIO, API's to transfer data and commands over MQTT telemetry and integrate with all home Smart devices, sensor networks etc. Home Automation is not really a good description more the vehicle and standardisation for exchanging home information.
Why?
Well, I started integrating everything I could on Raspberry PI. Sensors, i2c, 1-wire, GPIO, SPI, USB X10, API's, webscrape etc etc. Then started to think about how to federate within a Home Area Network. I didn't want everything going back to a central computer in the home, more wanted to be able to have satellite control points with say a PI in the kitchen dealing with communications for appliances, another dealing with living room,a nano for weather, satellite arduino mediators and of course small IoT devices on ESP etc. MQTT was the obvious answer for M2M communications because of the lightweight nature of the clients BUT you end up with a jungle of hard-wired scripts to maintain on each node. Every setup needs the tinkering with GPIO for sensors and displays, the 1-wire bus setup, the I2C setup, - and of course all the setup of pub/sub topics. So the idea was to create a metadata-driven wrapper around it all, harvesting environment setup by interogating the OS and adding data to allow it all to be consistently addressed through an abstrated driver layer. As this data is organised it is used for automated setup of publishing (sensors, inputs, web data) and subscription for controls (displays, connected devices, home automation controls)
Again, I know there are many available products for this that may get near to where I need (such as openHAB) but I really wanted total flexibility for extensibility. The world is moving fast and I need to be able to plug into iot services quickly (and sometimes those that wouldnt be supported in a product). So this will remain strictly HOMEGROWN with a healthy re-use of Open Hardware and Open Software.
The main components (per HAN node):
  1. ENVIRONMENT DATA SCHEMES: Metadata & agent wraps over sub-systems
  2. BULLET PUBLISHERio: Data-driven, resilient, bullet-proof configurable Scheme Publisher for MQTT (configurable thru topic controls)
  3. DRIVERPACKi: returning 'readings' from multitude of Sensor types, API's, and all Input-bound interactions
  4. AGENT MEDIATORio: Configurable Subscriber / Mediator responding to topic controls and orchestrating actions with sub-systems for all connected devices inc displays (OLED / LCD), I2C output devices, GPIO drivers
  5. DRIVERPACKo: for data-driven actions on all connected devices, O/S commands, API's
  6. RULESio: Lightweight configurable M2M rules engine for simple orchestrations (major orchestrations handled in NODE-RED)
  7. STATEio: a lightweight persistent state store for short-term persistence
  8. BRIDGEio: for handling M2M & Broker bridging between HAN MQTT and external / cloud iot services. (Adafruit.io, Arduino.io, Artik, PubNub, ThingSpeak, IBM Watson)
  9. API G/W: Currently supporting Weather Underground, Google Docs, Twitter, Email.
  • Updates for mSB
    Mark Traverse02/24/2017 at 13:03 0 comments
    latest additions include
    -- added an internet speedtest wrapper to api to return, publish and log upload download and ping to ISP speeds
    -- added an API wrap to iCloud to return and publish battery levels and locations of all family iOS devices iPhone, iPad, iwatch
    -- imposed a data payload standard based on Jason - this means all response or acquired data is self describing and can be passed and manipulated freely within the ecosystem
    -- added a learning two way IR and RF capability based on both broadlink devices and arduino-based homegrown transceivers
    --added rm tasker Alexa bridge to push macro if and rf out to broadlink blasters
    -- added an ir rf sniffing capability to intercept and record activity for re-use
    -- added a find phone mqtt subscribed topic to trigger find phone
    -- added an Amazon Alexa trigger bridge to republish and route 'Alex Trigger Action' commands, this relies on a public mqtt platform bridged to Han.
    -- added google text to speech and a proxy robot personality to act as intermediary until the Echo can be driven to speak and notify via an api. The later will probably never happen due to security constraints, so my solution makes all speech appear as if from the echo itself. Commercial natural language voices are supported.
    -- started to test a fake wemo bridge based on esp8266
    -- added google sheet integration to pull metricated data into the robot personality. I.e. Your car mot is due pin a months tim
View project log
