- Put image to another 6 plates - 3pcs of 5AND, 1pcs of 2AND/2OR, and 2pcs of D-trigger. Need to etch them but first want to image other boards for batch eching :)
- Finished with Memory Board routing. 3D Looks very good. Yeas, Most IC's are in DIP - this is because I have a Lot of Soviet IC and use them. Need to check all connections and will send routing to pcb maker - I can't do so big pcbs (300x200 mm ) at home.
- Routed 2ANDx4 pcb - I got single-side pcb again. Will use this type of module as a key module (four modules per bus) and in sequenser module where after 10-stage sequenser and diode matrix I will need to send signals to blocks. 3D looks good. Will do this modules at home.
- Prepare plywood table for photomask - it's ready for use and I want to start when finished with all known boards.
