I'm done with Adder block wire-wrapping. 32 modules, 2 modules per bit. Bit Placement:
Top rows - FEDCBA98, Bottom rows - 76543210, So two bytes in natural view
Not good with wire-wrapping yet - can't place wires smoothly, but already can do isolated turns.
Next steps - need some test suite for checking blocks
Yes, I'm using screwdriver-type tool, but do some non-stable pressure during the whole process.
Thank for advice - I'll try your tip while doing register blocks.
Your wire-wrapping looks a lot better than what I was doing in the 70's :-) I am excited to see how well your Brainfuck computer works :-)
Thanks! I hope I'll done with first revision in 2018 :)
