I started making BrainfuckPC base plate and for doing that I need full 3D model of PC.
I created all blocks with different assumptions. It's a final blocks arrangement! Final dimensions are 1000 x 650 mm.
Base plate - Aluminium 6mm. Work is in progress, so you can check current model state on Autodesk site here: https://a360.co/2rnFQnh
