This project is sponsored by PCBWAY. It is world fastest pcb manufacturing company.
You Will get FREE prototype pcb from PCBWAY. So do not be late to register and place your first order from PCBWAY
If you want to order pcb from PCBWAY . CLICK IN THE LINK BELOW:
https://www.pcbway.com/QuickOrderOnline.aspx?from=electronicsworkshops
Code
#include <stdio.h>
#include <string.h>
#define DEBUG true
#define MODE_1A
#define DTR_PIN 9
#define RI_PIN 8
#define LTE_PWRKEY_PIN 5
#define LTE_RESET_PIN 6
#define LTE_FLIGHT_PIN 7
String from_usb = "";
void setup()
SerialUSB.begin(115200);
//while (!SerialUSB)
; // wait for Arduino serial Monitor port to connect
delay(100);
Serial1.begin(115200);
//Serial1.begin(UART_BAUD, SERIAL_8N1, MODEM_RXD, MODEM_TXD);
pinMode(LTE_RESET_PIN, OUTPUT);
digitalWrite(LTE_RESET_PIN, LOW);
pinMode(LTE_PWRKEY_PIN, OUTPUT);
delay(100);
digitalWrite(LTE_PWRKEY_PIN, HIGH);
delay(2000);
digitalWrite(LTE_PWRKEY_PIN, LOW);
pinMode(LTE_FLIGHT_PIN, OUTPUT);
digitalWrite(LTE_FLIGHT_PIN, LOW); //Normal Mode
// digitalWrite(LTE_FLIGHT_PIN, HIGH);//Flight Mode
SerialUSB.println("Maduino Zero 4G Test Start!");
sendData("AT+CGMM", 3000, DEBUG);
void loop()
while (Serial1.available() > 0)
SerialUSB.write(Serial1.read());
yield();
while (SerialUSB.available() > 0)
#ifdef MODE_1A
int c = -1;
c = SerialUSB.read();
if (c != '\n' && c != '\r')
from_usb += (char)c;
else
if (!from_usb.equals(""))
sendData(from_usb, 0, DEBUG);
from_usb = "";
#else
Serial1.write(SerialUSB.read());
yield();
#endif
bool moduleStateCheck()
int i = 0;
bool moduleState = false;
for (i = 0; i < 5; i++)
String msg = String("");
msg = sendData("AT", 1000, DEBUG);
if (msg.indexOf("OK") >= 0)
SerialUSB.println("SIM7600 Module had turned on.");
moduleState = true;
return moduleState;
delay(1000);
return moduleState;
String sendData(String command, const int timeout, boolean debug)
String response = "";
if (command.equals("1A") || command.equals("1a"))
SerialUSB.println();
SerialUSB.println("Get a 1A, input a 0x1A");
//Serial1.write(0x1A);
Serial1.write(26);
Serial1.println();
return "";
else
Serial1.println(command);
long int time = millis();
while ((time + timeout) > millis())
while (Serial1.available())
char c = Serial1.read();
response += c;
if (debug)
SerialUSB.print(response);
return response;
